Hello everybody
I have 2 modified RS-B965 and have some questions, if somebody can help.
1. Two exactly same models, one from earlier and the other one from later series, same pb level, but first one peaks to 1db more and have output higher than 400mV, the other one peaks 2db more than it should and have even higher output. Peak-meter can be adjusted by replacing R41 and R42, and eventual difference on the output can be after-adjusted by replacing R47 and R48. Question: if anyone have 965 (untouched would be better) and is willing to check voltage on IC7 pin 2 and before/after R45/R46.
2. Have tested sweep signal through both of 965 and one 727 using Audio Tester. Seems that both of 965 aren't linear at lower frequencies. Even worst, 727 which is simpler than 965 is more linear. Anyone have an idea what can have an impact on lower frequencies? Observe that I'm not talking about recording, just signal thru a deck (loop). Se picture below, used signal was sweep -24db, attenuated to 0db (output 400mV) on a decks and both 965 have almost the same result. Blue line is 727, dark green is 965 and light green is direct loop on a sound card.
