- Jan 14, 2011
- Gillette, Wyo.
Meter shows 3.8....
Enlarge A specially designed autotransformer having low DC resistance (0.382 Ohms) and tight coupling provides taps to allow squawker level setting changes by the customer. The choices will be 1 to 18 dB in 1 dB steps, Attenuation is selected without soldering by push-on terminals and without cryptic setting tables. The attenuation settings are clearly written by each tap in dB units. The normal setting will be 6 dB. This adjustment will also allow the use of 8 or 16 Ohm squawker drivers without modification. NOTE: Any transformer that is larger in size is a waste of money. It will handle 50 Watts of power without batting and eyelash with virtually no loss, That is already extravagant considering the power levels through the midrange in a Klipsch loudspeaker will generally be less than ONE Watt!Meter shows 3.8....
So here is 2 different brands, both rated for 8 ohms, not that the meter readings mean much but it has to come into play. My custom crossovers are reading 4 ohms also.
yours have custom crossovers????
View attachment 28855View attachment 28856
I used Crites crossovers on my cornscala's but they are all close. I guess you would call that ESR??? Equiv Series Resistance????
I guess the next question is what is the frequency of the current generated by Mr. Fluke?
I guess not ESR but impedance from the meter which uses a dc battery and they are rated at the AC level (the speakers are).
Yep, a lot of stuff I don't understand yet. I'll find that article by Al where he explained why the amp would see 8 while it measured 4. It's on my backup drive , since my XP machine went tits up, I haven't moved a lot of files over..
Mr. Fluke uses a battery. I think they are using a known resistance, or voltage or current to display what you want to look at.
the caps and inductors act different to either
