Skynyrd77's Thank Godamighty , Finally My Own WOPL Build Thread!!
Skynyrd77
Mill creek Indiana
lost in my own world
#82
It's damn noisy, residual is 465 microvolts on one and 2.6 MILLIVOLTS on the other. THD & N is good, Signal to noise ratio is 30db on one channel and 80 on the other... 2.6 millivolts is a TON of residual noise, should have ben able to hear that buzz for a mile...
You got to realize it got no kind of true listening lol. I was happy as hell cosmetically and scRed of it at same time lol. I don't remember a buzz but I'm sure I had one at the time. So I know it looks nice lmao
#83
The protection circuit limits current X voltage = power dissipation in the power transistors.
It's similar to a power supply protection circuit that I discovered by accident a long time ago that measures the voltage X current in the transistor, but the difference is that this amplifier protection circuit measures the voltage X current in the load instead. This means that the operation of the amplifier protection circuit is not affected by relatively minor fluctuations in power supply voltage.
The amplifier protection circuit automatically reduces the current limit if there is too little voltage across the load, caused by the load resistance or impedance being too low.
It's operation much more similar to a power supply foldback current limiting circuit.
Correct, SOA protection is a function of the product of the Collector-Emitter voltage across the transistor and the collector current through it. The circuit involved takes both into account in determining if it needs to clip or not.
#85
At 4 oms loads, it clips at 55volts....that equals 14 amps of current.....
At 8 ohms load it clips at 63 volts....that equals 8 amps current.......
Things are not linear...so there is a voltage component to the protection circuit??
And it is likely clipping in both cases from the influence of the protection circuit.
Skynyrd77
Mill creek Indiana
#87
Wow. I think I might understand this a bit. Huh. I guess the word protection means to protect even if in doing so it screws up other stuff. Am I right? Or should I just stay out of it lol
#88
And pushing it further without blowing a fuse will just annihilate the output stage...
#90
No , Jase in this case the board protection circuit shunts extra current away from the output transistors without hurting any components, it's desigh intent, up to a point...that coupled with the 5 amp rail fuses have serve it well since it was made. By putting in 10 amp rail fuses we have taken that option away...
#91
Meters isolated, i have effectively rendered D9 non-operational in the left channel....
Skynyrd77
Mill creek Indiana
#93
Oh ok Ic . I forgot you basically took it out of normal operational mode when you put the big ass fuses in. I think I got it.
#95
That nagging question eh?? You funny Joe. Yeah, 4 amp compared to 16, jeez. Ok , one more question. On your board did you up the SOA for the better outputs of today?
#96
Changed Channekl 2 to AC and put it to monitor the left channel---the "unprotected" channel. Letting things cool off for a minute or twi then we'll have our answer....
#98
Yes slightly Lee...remember these started out as aftermarket boards and there are many of them installed with the original PL909's in place. Can't go too crazy.
