- Jan 14, 2011
- Gillette, Wyo.
Joe, any problem jumping the unfused B+, B- from the right board to the left where those enter the left board??
OK, I know I've shown a preference for separate feeds to both sides of the board, but that approaches the inane in this instance. I have to literally go right over that open hole in the left board....
Well, I couldn't do it. Smacked of laziness, so we ran both boards to the power supply. Also tried something new this time. Ran sleeving for the top run of wires and cut entry and exit holes. I like it,,,,A lot.
I love the stuff already. The DCP is in just for fitting purposes. The real one will be soldered in. Much neater with the wires coming up from underneath.
I see you like that silicone impregnated tubing Lee.
The DCP looks nekkid.... I like the uncluttered look around it though.. Gotta take the BABB to the shop and round off the corners on the belt sander, It'd take me hours of filing. Back in a bit, Bout time to mount a board and test this puppy.
That is looking pretty sparse - but it is missing a major component. Damn without the connectors and Zobel it is really nekid. I like nekid though - maybe you didn't know that.
Like a fiddler crab??
