- Jan 14, 2011
- Gillette, Wyo.
Channeling your inner Red Hot Chili Peppers eh?
Or OffspringChanneling your inner Red Hot Chili Peppers eh?
Do both. Washers plus heat shrink between. Can’t hurt
That's why I like them...These guys videos are nuts.
I'm going down and watching this right now on the big screen with THE SYSTEM.These guys videos are nuts.
You may need to lay down the bridge rectifiers George.Got the 2 digital Cylon meters built
Next step is examining all 5 boards under magnification for solder balls, splatters, whiskers, and proper polarity of all components. Should have no issues, but it's a critical step.
Might get to mocking up the boards in the chassis next weekend. Wiring also needs to be cut to length and tinned. I bought Joe's wiring kit which is a must have. Joe has a wire cutting length guide which is spot on. Additional wire is advantageous to have. It'll all be Teflon insulated silver plated copper.
Oops, will do! Easy enough! Thanks.
Really should not use Keps Nuts on PCBAs George. I know PL did but they did a lot of things that you shouldn't. For PCBAs, I always go with nylon washers interfacing to the board itself.Thought I'd post this photo. There was no round builders sticker on the chassis backwall as normal. Only round sticker is on the intermediate plate, says "Sub.F." and cursive initials I can't decipher. The rectangular tag was under a Zobel Network power resistor, hence the heatsink compound. Says Unit #5 of 50.
Far as I can tell, Audio Analysts was a company in Colorado Springs.
Will do, will switch them out. Thanks!Really should not use Keps Nuts on PCBAs George. I know PL did but they did a lot of things that you shouldn't. For PCBAs, I always go with nylon washers interfacing to the board itself.
KEPs nuts sometimes score through the solder mask and if there is trace in the area, will begin the corrosion cycle for the underlying trace.
