- Jan 14, 2011
- Gillette, Wyo.
Film caps are what I use on the 400's and 700's. I wrap the leads around the tabs instead of drilling...turns out pretty nice..
Cool, yup, already got the extra holes drilled. Now measuring and cutting backplane wire after cleaning the leaves out of the gutters. Might even cut the grass this afternoon for the final time. Gotta wait for the sun to melt the frost first. That last system that blew thru stripped every last leaf off the trees. I'll mulch what's on the ground.Film caps are what I use on the 400's and 700's. I wrap the leads around the tabs instead of drilling...turns out pretty nice..
Yeah, a guy should build at least one...![]()
When I built the 400s I bent the bias transistor leads to a 90 and soldered them in. Mark L. posted he solders them in straight, then bends the transistor over. That's what I did this time and it's far easier. Used a short pointy needle tip and turned up the heat to 750 because their is so much copper in that area. Done and looks good.
Thanks Joe, guess the fine tip and double sided board tricked me on the 400s.Hi George
Actually there is very little copper in the bias transistor area. If you hold the board up to the light, you will see that all the planes have been voided in that area to minimize stray capacitance which would upset the amplifier performance.
Hmm, was looking for something similar, but old style, pre-plastic. Phase Linear used a woven flexible tube to protect the power cord on a long run inside the 400s. Looks almost like fabric, probably flame retardant.View attachment 58523
This stuff on my power cord?
My local (gold mine) has it in eleventeen colors and sizes
McMaster Carr. High temp expandable sheathingAh, cool, woven glass, like fiberglass cloth. Your right on the money I believe, it looks very similar to woven fiberglass cloth used for auto body repair. That helps a bunch. Thanks!
