PL 3300 Series II rebuild/upgrade
#81
it looks like you have +unreg on one side of R1, and + reg out on the other side of R1 without R1 in the circuit. Can't work like that
Z102 A,B = B&B OPA2134PA. I'm going to have to go look up the pin outs to take any measurements on the other OPs.
#88
You gotta pop the top of your other preamp and look but I do believe your power switch is wired wrong. That would account for the button not working right. Sounds like a set of contacts are welded. 3 of the 4 contacts are soldered together. You can see that it's not right.
Okay, just to get everything straight — I'm attaching Lou's original instructions for his board. His paper seems to indicate that 1 & 3 should be replaced by the leads from his board. Are you saying the board I have requires the resistors to remain in place?
Okay, I'll go in now and pop that top so I can take a look.
#91
Does your power LED stay lit? You have at least one constant hot wire, very dangerous. That Black wire is jumpered to 3 tabs of that switch eliminating the on/off function
Okay, I just pulled my other 3300 in here to the shop. I don't know who messed with the power switch on the unit I'm working on. It came to me that way. Clearly, I need to pull the whole thing loose and get it wired properly. When I did the build, I was using the schematic. I definitely wasn't winging it. But the issue seems to be those resistors, which are not in the board on my other unit, which I rebuilt years ago now. So I don't have direct recall of what I did back then.
#95
Your pictures are too big, use PIXresizer if possible. DO NOT REUSE THAT SWITCH... It is compromised. Replace the switch, and fix the wiring on the power supply.
#98
I'm not having any problems with images, and although 6 MB is a little large the detail is really nice. That being said you probably don't require more than 1100x tops.
I use PIXresizer and the pictures take no time to open, and are sharp and clear.
