- Mar 6, 2022
i was just reading...and i see similar on amazon and ebay....thanks so much for the tutorial...Yeah Gene.
Got rid of the contractor grade power strips.
Put in two Furman PS-8R Series Two.
They are the 15 amp models.
There is a 20 amp pro version with the 20 amp plug, but I went with 15 amp because I have two available 15 amp outlets.
They advertise "power conditioning", but I'm a skeptic. I'd go with a couple massive isolation transformers instead.
I bought them because of the sequential equipment power on function.
They have a jumper across the back, so they are slaved to each other.
Eight outlets across the back and one in front of each unit.
Press the master bright orange rocker switch on, and the front outlet and rear outlets 1+2 become hot.
Press the sequential start switch on either unit (they're slaved with a jumper on the back) and rear outlets 3+4 on both units become hot.
Stand back, and in 5 seconds (a internal adjustment) outlets 5+6 on both units become hot.
Wait another 5 seconds, and rear outlets 7+8 of both units become hot.
System startup is complete.
Preamp, MiniDsp, tuners, turntable, are powered on first in both units outlets 3, 4, 5, 6. That's eight outlets in two Furmans.
The four amps, a 700 Pro WOPL, two 400S2 WOPL, and a 300S2 get powered dead last in the sequence on outlets 7+8. That's the last four outlets on the two Furmans.
Shut down is the reverse.
Hit the power sequence button, amps get turned off, then everything else in sequence.
No pops, no power surges. Proper start up and shutdown every time.
Now the bad.
These old Furmans are still bringing good money on the Bay.
They'll need recapped at a minimum due to age and the fact they came with no name cheap caps.
They're loaded with relays, two SIP resistor packages, a timer IC, a opamp, handful of transistors.
I got the cheapest units I could find that weren't totally scraped up.
One just needed a recap, the other needed a recap and the timer and opamp IC.
Couple months back I replaced both power rocker switches. Exact replacements are available from Digikey or Mouser.
I really like them, a must have with a four way active system.
That's appx 1800 watts in 8 channels going to 8 drivers. Nothing is in-between the amps output and the drivers. No caps or resistors, just Monoprice wire.
Power strips just wouldn't cut it anymore.
i feel exactly as you do...i like the sequence powering...and line conditioning...although i am sure not as good as isolation transformers...but, the are pretty costly....
i will do more research....too often i buy quickly only to find a better opportunity that i wish i would have waited for....
thanks for the info!!!!
again, very helpful...
what i would really want is a diy kit...but, so far no luck finding one...nor plans for one...
but, i will search more...
pura vida!!!!
