- Mar 6, 2022
i wish i know now what you all knew then...
i hate it when that happens ....Did you replace the the 10 Ohm resistors -YES
What is the voltage on R25 - AROUND 7V, however, tough to get a measurement given i have about 4 seconds to work with.
If you lift on leg of D12, does R25 still get hot? - N0 LONGER GETS HOT
Remove the yellow wire on the control board for the Right channel - R25 gets hot AND R23 pretty much burnt up immediately. Replaced R23, hooked yellow wire back up. R25 gets hot, bias .550.
Bias transistor jumper test - bias remains at .550 and R25 gets hot.
well, dont remember how long ago i ordered the light board for the last pl400...
but, it arrived today....i am sure it was more than a month...
welcome to costa rica!!!!
will install tomorrow...and wrap that puppy up!!!!!
you dog!!!April 2nd, 16 days ago. You probably use that same line when you tell Maria what 6" is too![]()
My order queue clipboard just turned up empty this afternoon, so you are next up Richard.mr joe, am I in the que for those boards I ordered?![]()
been there!!!Awesomeville!
forgot pic...this is my original wopl!!!done...new l8ght board installed....
all units up...running...lit up!!!
using 4 pl400s.... 2 spares...
working on meters for haflers...one more to do...
its been interesting!!!
that is a reflection in left meter...not cracked...forgot pic...this is my original wopl!!!
i think i got some!!!Dielectric grease may help.
