Sunnbobb
I didn't say Saint! hahahalololol...
words ive never heard before...and certainly never again...
lololol...
i must admit this is a very nice forum...with quite a few very nice people willing to share their knowledge!!!
lololol...
Please include a snippet of the schematic you are referencing for the R25 callout. PL has many schematics, none very consistent. We want to get to the heart of the matter without a wild goose chase. 0.550 bias is not a good situation. Likely caused by a defective Q7 or Q10 on the control board schematic.Well, I'm back, did you miss me? hahaha. So here is where I am at. The PL400 with PL14 board. I have now replaced the transistors with new 96's, (bottom row are 410's). My DC offset on both channels is almost undetectable. The Bias on the left channel is set at .360, however the right channel bias is at .550 and is not adjustable with the pot. The amp fires up, the output relay does it's job, and the tight channel (farthest from the transformer) R25 resistor slowly burns up. I takes a couple minutes, but eventually it gets super hot and smokes. I've replaced and the symptom remains the same. Anyone know what is causing too much voltage to that resistor? I traced the schematic, but don't see a clue.
R41, the 0.22 ohm resistor on the back wall may be open. You should check.here is the impacted R25. Thanks for the help!
