- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
Just a jump the gun theory at the moment, but let's say it works like this..
1. Button pressed
2. Controller IC "allows" TDA to swing into action, driving the motor
BUT
3. Controller IC is also just a split second layer EXPECTING the limit switch to change states i.e. either the drawer has started traveling to "closed" or "open", depending on it's previous state.
AND
4. Either the delay isn't long enough anymore.. Controller IC says "well.. I don't see it opening or closing", so I give up
OR
5. The voltage differential being presented to the motor is NOT enough anymore, therefore the TDA needs replaced.
Soo.. perhaps there may be an outboard cap around the controller IC that through typical RC action is in charge of this delay... and is shorted..
or
TDA chip bad
or
Controller IC bad
1. Button pressed
BUT
AND
OR
or
TDA chip bad
or
Controller IC bad
