OK,time to get serious now.......
#23
I do not Ron. The copper they use for plumbing is generally the not grade for machining. C145 is tellurium copper and is generally used where copper machining is involved.
I was using hard 110 for mine..
gadget73
Do you have to use the backplane boards with a WO driver board? Couldn't he make it full comp using the original style wiring and just connect that to the new driver board and keep the original chassis and such ?
#25
Yes he certainly could...and Ed has done so many times with the stock boards. I don't know of anybody who has taken a Rev D board in full comp mode and converted a stock backplane setup, but it can be done...
grapplesaw
Vancouver
So it's time to get started then. Not to many changes . You need extra wire to 27 connection on the control board I think. I may have a schematic. I do have series two comp schematic.
Suggest adding a mirror ferric bead
Glen
#27
Maybe you can sell them and turn the cash into heat sinks. :wink:
I sure I could but where can I buy the heat sinks made for the amp. Then there is the little problem installing them as I would be in territory I don't want to be meaning I would have to start taking apart stuff I know nothing about and no correct tools and also gadgets to test with. I would love to have Silvara/Sally to get copper fins, copper lined interior and maybe a new copper faceplate. I would imagine the copper would have tp be coated with something so you don't end up with an uglyassed tarnished out amp (think how an old penny looks after while)
#28
a nice green patina!!
#36
The only thing that should be green in an amp is a FEW wires....jeez people.....GREEN?????
