- Jan 14, 2011
- Gillette, Wyo.
The row closest to the transformer is for the MJ 21196's, the next the 21195's, then the 96's then the 95's...
Thanks Lee! Easy enough but didn't want to just wing it and hope I guessed right!!From previous reading I remember that I'm only supposed to install the transistors in four slots initially, I believe it was QX17 & QX18, on the left and right boards in order to more safely apply power for the first time. Do I understand that correctly? Thanks again.
Nelson
Put in the bottom row only which is XQ11 and XQ12 locations on each backplane board. Do your power up with variac and DBT to check things out before installing the next row, then the next row etc.
this is incredibly helpful. I went over the capacitor installation instructions quickly on the WO site but will go over it in earnest tomorrow when I print it out. It's easier for me to read on paper for some reason. I'm guessing that where the yellow wires go will be (hopefully) cleared up in that document. I'm positive they were attached somewhere in the old configuration, I'm sure I cut them leaving as long leads as I could, but I didn't pay attention where when I disconnected them, thinking it would be obvious later. I'll be taking more "before" pictures on my 700B project, to be sure!
Anyway, thanks again Joe, looking forward to these next steps and a successful power up. Wish me luck!
Thanks Joe and Lee, good advice for sure. The straight edge test showed everything to be good in that regard, so that's a good thing. I've attached a couple pics of the boards in the chassis.
Doug (fitz43) has some silpads in the mail on their way to me. Progress!
View attachment 19539View attachment 19540
Your AC wiring in this picture is NOT correct Nelson. Right now you have it wired such that the AC Neutral and Hot line are tied together through the fuse holder.
AC wiring should be as follows:
AC In1 (short wire from line cord) to AC mains fuse TIP
AC mains fuse RING to transformer BLUE and BROWN wires connected together
AC In2 (long wire from line cord) to Thermal Cut out switch terminal 1
Transformer Yel/Blu and Yel/Brn to Thermal Cut out switch terminal 2
Let me know if you are clear on this?
So if I understand you correctly, I remove the white wire from the fuse AC mains fuse tip and the thermal cut out switch and put the yel/blu & yel/brn wires to the terminal on the cut out switch where the white wire is now. Would it be best to splice/extend these two wires and route them above the boards to avoid having them in between the backplane board and the control board or can I use them as is?
AC In1 is where it is supposed to be, on the AC mains fuse tip, as is AC In2 which is routed to the thermal cut out switch. I did remove the strain relief as suggested and feed an extra inch or so of the AC mains cord inside the amp.
The blue and brown wires are already where you say they should be, I believe, as they are currently attached to the AC mains fuse ring (side lug).
Does it sound like I've got it right now?If not hit me over the head with it again, it will sink in eventually!!
Yes, get rid of that white wire you have routed to the thermal cut out switch and extend the joined yellow/brown, yellow/blue wires over the top and then L down to the thermal switch. You can use that white wire to extend the yellow/blue/brown wires to save having to solder that end again at the thermal switch.
DO NOT run the AC wires over the backplane boards.
Sometimes the self-tapper leaves a rather crude thread. Double nut the threaded rod and try using a small wrench to turn the rod..
Or better yet, take a 10-24 tap and chase the threads.
The row closest to the transformer gets the 96....the 95....then 96....then 95..
