Put in the bottom row only which is XQ11 and XQ12 locations on each backplane board. Do your power up with variac and DBT to check things out before installing the next row, then the next row etc.
Here is the recommended procedure Nelson. This was written for the quasi-comp with the RCA410 devices in the bottom row, you can substitute XQ11 and XQ12 for the RCA410 references and the remainder is relevant to bring up.
With this configuration (somewhat like safe mode), you should be able to power up the amp WITH NOTHING (except a DMM) CONNECTED TO THE OUTPUT AND NOTHING CONNECTED TO THE INPUT.
This will allow you to check everything out before doing any further work. The amp will work in every normal way except that it will not be able to power much of an output load without the 6 or 10 (depending on PL400 or PL700 amp) remaining output drivers per channel installed.
Step by step:
1. Check for any shorts or workmanship issues
2. Turn bias pots on control board to full CCW position (bias set to minimum, bias level setting is of no real concern during bring up unless Q6 is broken)
3. Install 1A fuses in the B+ and B- fuse holders
4. Attach DMM in voltage measurement mode, plus lead to the left channel speaker white output post and minus lead to left channel speaker black ground post.
5. With the Variac off and dial turned to minimum, plug in the amp to the Variac output.
6. Turn on Variac and slowly (over about a 30 second interval) bring the dial up to 60V input. Pause approximately at each 20V input interval along the way to 60V and ensure nothing is abnormal and your DMM voltage is behaving reasonably. Ensure no overheating, smoke, bad smells etc. Shut it down if you do!
7. If you made it this far and things are OK then check the output of your DMM. It should be very close to 0 V, typically less than 50 mV. Ensure no overheating, smoke, bad smells etc. Shut it down if you do.
8. Next slowly (over about a 30 second interval) bring the dial up to the full 120V input. Pause approximately at each 20V input interval along the way to 120V and ensure nothing is abnormal and your DMM voltage is behaving reasonably. Ensure no overheating, smoke, bad smells etc. Shut it down if you do!
9. If you made it this far and things are OK then check the output of your DMM. It should be very close to 0 V, typically less than 20 mV. Ensure no overheating, smoke, bad smells etc. Shut it down if you do.
10. Using your DMM plus lead (with the minus lead still connected to the left channel speaker black ground post) check each of the 2 bias test points on the control board. These should measure less than 0.400V (typically these will be at about half of this with the bias pots turned to minimum)
If all goes well in the above 10 steps, you are ready to install the next row up from the RCA410 pre-drivers. Allow the amp to discharge prior to the installation of each next row of devices. Unplug the amp and let it sit for 5 minutes before installing each row of additional driver devices. You do not want to damage output devices or yourself by working on a somewhat live amp. The rest of the tests are somewhat continuous with no discharge need involved. Carefully check each device installed using your DMM to ensure that they are good devices and then install the 4 drivers in this first row above the pre-drivers. After this step is completed:
1. Repeat step 1-10 from above.
If all goes well in the above 9 steps, you are ready to install the second row up from the RCA410 pre-drivers. Allow the amp to discharge prior to the installation of each next row of devices. Unplug the amp and let it sit for 5 minutes before installing each row of additional driver devices. You do not want to damage output devices or yourself by working on a somewhat live amp. The rest of the tests are somewhat continuous with no discharge need involved. Carefully check each device installed using your DMM to ensure that they are good devices and then install the 4 drivers in this second row above the pre-drivers. After this step is completed:
If all goes well in the above 9 steps, you are ready to install the third row up from the RCA410 pre-drivers. Allow the amp to discharge prior to the installation of each next row of devices. Unplug the amp and let it sit for 5 minutes before installing each row of additional driver devices. You do not want to damage output devices or yourself by working on a somewhat live amp. The rest of the tests are somewhat continuous with no discharge need involved. Carefully check each device installed using your DMM to ensure that they are good devices and then install the 4 drivers in this third row above the pre-drivers. After this step is completed:
After all the above and things are still looking good, turn on the amp at nominal AC line voltage and let it sit for 5 minutes and then adjust the bias per the procedure.
This is the procedure that I utilize for a new amplifier bring-up. It does not take as long as the procedure seems to indicate after you have done this a couple of times.
