- Jan 14, 2011
- Gillette, Wyo.
Hi Bill!!!!! You lurker you, join up and put your 2 cents in!!!
Hello Bill.Thanks Lee! And Joe! i TRY to do the best work I can to my abilities. (Though they be limited). It was a joyous moment to send my dad home packing two powerful full-montied WOPL400's. I loaded them into his van and told him to enjoy them as he drove off into the sunset. He will be hooking them both back in-line tommorrow. I told him to call me and let me know how it sounds. He was ecstatic as it was.
And this is all from a guy who started out this saga by saying "I'm not paying x amount of dollars for something I've never heard before"? So I spent it for him initially because I already knew it was worth it. (He paid it back later and I told him not to but he insisted). Never did I think he'd do it a SECOND time! He's a convert for sure and I am glad we have this group of guys here to help each other out. You've saved my ass more than a few times to say the least.
By the way........He READS these posts. So everyone say hi to Bill.![]()
10-4 Joe. Spoke with my father. The amps may make a return trip in the near future. I will fix the wire routing up upon their arrival.You can fix your OCD concern by running the red and white wire from the DCP to the meter board laced to your grey ground wires and over to the meter board. likewise for the black ground wire coming in from the left, it can be routed with the other grey ground wires and over to the meter board. The central orientation applied to when you were running them from the backplane boards. But you have moved them.
Also in speaking with him on the phone this morning; he says the meters DO act that way on the old build. They just don't do it after the amp has been sitting off for a while. Like an hour or more. That's why it didn't do it here when I tried it. But turn it on and off again in less than that and they DO. I am presuming this has to do with the caps having their residual discharging in the circuitry or something? My no-knowledge 2-cents. SO NOW he DOES want me to move the meter wiring off the back-planes in the old build. So there we go. Good news on both fronts. I have asked for some more wiring kits. Can't have too much of that stuff lying around. Gotta probably be like Lee and have a hundred of everything...........
Got Joe's wiring kits in. Had my father return today with both amps in tow. I made matching modifications to both. Following Joe's wiring path instructions, I re-routed my AC and DC the best I could. Some Consideration given to the two facts that A.) I already had the backplanes in and wires soldered to em, so lengthening them wasn't an option at this time, and B.) My dad, (the customer) did not want to cut to length the original transformer wires (gray) to the light board. So I made a service loop. Right or wrong, that was his decision.
So this solved the hum I got when only speaker wires were hooked up. At least to the point it was only audible if you smashed your ear into the woofer. It was faint at best. The minute I plugged ANYTHING in to the RCA jack though, we got a louder hum. Both amps, regardless if a source was at the other end. Yes my RCA jack are floating and I metered them to chassis. -No continuity. So considering the test bench had an iphone and a crappy pair of RCA's just for testing amp function, we aren't sold this is actually an issue. He said he couldn't hear it at home BEFORE I re-routed the wiring. Only if he walked up to the speaker and put his ear into it. He's not concerned about it. I DO have that meter attenuation switch washer touching the bottom binding post nut and those two ring out to chassis, but since the binding post core is plastic, I can see only the attenuation switch body being an issue, but it's not because it doesn't ground out to anything else. Would a three prong plug solve some of this? Or is it inherent in the amp build? (i.e. new sensitive parts that can pick up things a lot easier)? I'm just pissing in the wind there so take it with a garin of salt. Joe said his Acurus pre, brings in hum when he hooks to it too, so I presume it to be? The old PL wiring didn't do that though, so I'm wondering what is the cause of it? The great news is, the meters no longer bounce on turn on/off and are protected by the DCP, so I AM glad everyone here prompted me to make sure I made that change while I was in there.
Anyway, that's the last I'm touching the amps. They are DONE. He is SATISFIED, and that's probably it for him. Below some shots as received together, and then one of each AFTER I re-routed the signal paths. The Saga is again...........OVER. Enjoy the amplifier porn............
Yup. We had the same results here after the re-routing. So we are good.Hi Dave
One day, if I ever have time, I will fix the faint noise originating from the Acurus pre.
Like I said earlier, I have to have my ear literally on the speaker to hear it.
The rerouted wiring looks great. You should not have had to do anything with the backplane wiring other than the meter wires
YES. NO RCA's were hooked up whatsoever. Just the bookshelf speakers to the binding posts. Same when I moved it inside to the Acurus system and the Giant Speakers. Same result at my fathers house as well.When testing amps for residual noise it is common practice to use shorting plugs on the RCA's, always has been. So are you saying you were fighting this noise problem with the RCA's unused and bare??
Good eye. Yes that was in the middle of adding new RCA wires. Obviously work in progress. I can assure you everything got blown out again with and air compressor to ensure nothing like that stays in there. (OCD wouldn’t allow it.) Probably spent ten minutes cleaning it back up again after making Joes changes.Did you just snip the # 5 wire off @ the back plane or take it all apart again to unsolder it ??
I'm glad to see this post and Joe's revision.... I've been chasing low level hum on my WOPLS's also ...
Btw, I spotted something in the top right corner sitting on the back plane, rouge shred of wire ?
M
Anyone out there know where I can get help with 700 2 would build that's gone wrong shorted output I live in ark 2nd tech I tried won't work on pl
