8991XJ
- Oct 8, 2011
We usually unsolder the wire wrapped pin instead of cut or unwind the wire. The wire wrap is an excellent connection. But I've done it both ways. I even had a recapped unit here where the guy doing that work cut all the wires leaving a stub of the insulation as a marker so the wires could be reinstalled properly. But that wasn't even necessary as I have recapped the same unit without moving any wraps, just positioning the board as needed for the work with wires attached.They left enough wire such that I don’t have to unwind the wires from their posts.
I hate it when problems arise. Probably because I'm better at replacing parts than figuring out how stuff works which leads to determine why it doesn't work. Hope you get this one up and running easily.
