- Jan 14, 2011
- Gillette, Wyo.
Those 50 ampersand we put in should be good for the life of the amp...
The fan outlet would be unswitched. If you want to do that, just leapfrog directly from AC input as I did with the neutral wire. The original wiring had the fan outlet switched and I wanted to keep it that way, but nothing says you can’t leave it live. Some have even omitted that outlet altogether.Great video Mark. Your description of the power switch loop/thermoswitch black AC wire got me to thinking. I might run the fan AC jack black wire to the closest thermoswitch "hot" terminal rather than back to the transformer terminal strip. That way, if the amp overheats and shuts down due to a thermoswitch opening, the fan AC jack still has power, so the fan stays on to help cool the amp. Plus, it's a shorter run for that black AC wire.
Thoughts?
I’m not satisfied with it. Bad continuity, choppy editing, and I restarted the wiring part twice because I didn’t have the grade of wire I wanted. I tried to cover too much in the original video and tangled how I wanted to make the presentation. Short videos hold attention better, smaller chunks of procedure allow better detail. Probably the worst video I made so far.Great video Mark.
‘Cuz I’m a bonehead?Hey Mark, why arent you wearing that fancy Phase Linear T shirt?![]()
Remaining stock:Where did you get it from? I want one!
First row went OK and 2nd did not? What control board, E5 or G1?Installed second row of outputs, getting -.6vdc at the +15 test point. What does this indicate?
All other TPs read correctly. Bad transistor?
L channel...
G1 control board. I replaced the outputs, same result.First row went OK and 2nd did not? What control board, E5 or G1?
First row was fine.First row produced good results?
