Looking to upgrade to horns
JustMike
"wherever she lets me"
"Just Passin thru"
#61
Ray,
I got most of my Altec stuff from a old theater that closed down years ago. I don't use the 811 horn with what I have set now. I'm using the larger 511 horn.
So I may have a pair of 811's in my stash. I'll check when it warms up a bit.
jM
roccus
Maine
You'll blow your ears out kid
#62
C
Ray,
jM
Cool let me know, and thanks for your input in what you have found that works and what don't it helps give me a direction on what to look for and what to pass over. Like I said it appears there are a bunch of these around and many just collecting dust and cob webs, if I can get my hands on a pair I will blow the dust and cob webs off and get them back to do what they are supposed to do
JustMike
"Just Passin thru"
#64
Yep .
Seeburg used Altec's 811 horn (painted them gold) and 806A Driver. I believe the Woofers were Jensen.
Heathkit also rebranded Altec horns, drivers, and woofers in there high end speaker cabinets
#65
Yep .
Heatkit also rebranded Altec horns, drivers, and woofers in there high end speaker cabinets
There's a tidbit I didn't know...besides most of the Altec horn numbers and stuff, great info Mike!!
JustMike
"Just Passin thru"
#66
Thanks Lee.
Lee remember the old Jubilee that was at one time said to become the Klipschhorn II . But was the moved into Klipsch's commercial line ?
I'm sure you have checked whats up in that division these days.
Here is a link : https://www.klipsch.com/pro/cinema/behind-the-screen
Looks like my stuff, big gray boxes with horns on top.
The WAF factor might be a problem for some. I'm a lucky guy, my wife loves the sound.
Interesting info on Klipsch's DSP system control also.
I'm not a fan of passive crossovers as you know and use an analog Pioneer SF-850 Active crossover , but this new digital DSP control
is very interesting. I've been reading up on using the DBX DriveRack PA2 for speaker management .
There is an article on the Great Plains Audio site how it was used on an Altec Model 14 . Its in there somewhere.
Ray,
You might find some of this interesting as well on the Klipsch pages . Looks like good DIY. Stack it up high with horns. lol
later guys,
jM
roccus
Maine
#67
JustMike looks like a big screen tv lol Looks like Lee needs to upgrade to some of those fully loaded 4 way horn grand auditorium systems... :)
jvandyke_texas
#68
Speakerlab was a Seattle company. Ks will be on the west coast. I have a pair I bought when I was 19. Mine have the HD350B and HT3500 drivers and horns. I have the 8 ohm 15" woofers. Later versions swapped in low quality mids and highs. You might consider buying a very ugly pair from Seattle and shipping only the speakers and crossovers. It probably won't cost that much. It is a lot of work to build folded cabinets.
They do have a full sound. Do very well on orchestra and rock. They are not the speakers you want for a punchy nightclub live jazz band reproduction.
They are also very efficient. Does not take much power to get a lot of sound. The folded cabinets use the room's corner walls as the throat of the bass horn.
#71
Built my K's in 1984....drivers were garbage so was the crossover, took me 25 years to make enough money to upgrade......but man was it worth it...
#75
B & C DCM 50's for another
For the tweets Crites CT 125's or B & C DE-10's....
I bought some Martelli "Tractix" wood horns for the BMS and B & C 2" compression drivers.
Of course if a guy had 15, 000.00 to throw around you could always get some TAD woofs, mids and tweets...
#80
1500 for a pair of DCM 50's , about the same for theBMS, then about 300 for a set of wood horns, then about 200 for a pair of CT 125 tweets.
300 for a pair if Crites woofs...
