- Jan 14, 2011
- Gillette, Wyo.
wattsabundant said:laatsch55 said:Yours tested over 500, 525 if i remember correctly, better than mine did.
A slight drop in line voltage will directly affect output power. at these power levels it would be expected to see the line drop a few volts under load. Compensatee with a variac.
As for teflon wire, I worked at a transformer shop many years ago. We stripped teflon with a red hot heating element. Standard strippers don't work because they can't grip tthe slippery teflon. Note that the conductors are silver planted.
Any wire used for the connections to the driver board should be stranded for flexibility.
Thanks Don. Stranded, silver plated , and teflon insul;ated wire sounds like just the thing for the driver board.
