Kenny Nelson's WOPL 400 conversion.
NavLinear
#83
I get a strong impression that Jani is way cool - Hi girl and glad Lee has you at his side - or maybe it's good you have Lee at your side! No matter - it's the match that counts.
#89
ken, whoever put in the LED's on the stock board hadn't a clue or the current limiting resistor and DC BR is in the base of them. If they don't have those they won't last long and if they do the lightboard is a mess, so I'm gonna put in a Joe board, they're white, see if ya like em.
#91
Just had to listen to this fine sounding sumbitch one more time, Probably set the bias while I'm at it....
#92
Looks much better with the White Oak light board Lee :) I am sure it looks better inside too. Cleaning up one of those messes right now myself.
#94
that is pretty typical, after several bulb replacements, those single sided traces give up the ghost.
Gibsonian
#97
Nice appearance and performance from that amp. Wow. I definitely like the white lights better than the blue.
#99
Ok Kenny, you've had it for a couple days now, time for the critical review...
Lickety Sp;lit is back. Shipping caused the allen head hold down screws to rattle loose and they then laid in amongst the back wall bussa bars and it got plugged in. Lights lit, 15.52 vilts DC on the outputs, no relay click, no burnt fuse, no burnt output, no burnt driver, hell, no burnt semi-conductor anywhere. R2R, R2L measured 656K, and 2 megohms. That's what burnt.
