It's getting late...
Affirmative and no video card to spare yet.
Fitz (Doug) is sending me a 7200 GS this week :)
I owe you, bud!
I hope the resolution is good enough...Navo's women are messing up my vision :la:
Depending upon what version of the 7200 it is, it might be fan less and have a resolution up to 2048 x 1536. :hello1:
It works too!
I'm not sure the board likes Cable Select though...no drives registered
You have to enable the sta or ide chipsets in bios. There is an Nvidia cip and a silicon chipset for the drives. "If you are using jumpers then you must be using IDE which will need to be enabled in bios also.
Now I need to locate another power cord so I don't have to keep unplugging this monitor to power the 'Cornea'.
It's the brand of the little 15" flatscreen monitor you sent me some time back.
I've got plenty of 'em, Navo sent one in my SS package even. I just have to locate the box of them, which will happen soon enough as I'm cleaning the place up for a housing inspection this month.
Yearly recertification of rental assistance.
Even if I weren't on a fixed monthly income I would not BUY a house.
And Asus A8N-SLI has no such switching in the BIOS. I'm going to have to set them up Slave and Master.
Nope you can enable and disable the ports in bios, slave and master need to be set on the devices.
