Inverted back plates build
#42
It is Alive
The hardest part was putting in the drivers. I remembered something about magnets so I got out my little pocket magnet pencil It made things much easier but still was a fight
I found that checking the leg alinement in an old base helped a lot
I must have stewed up something with the little inserts as they stuck up from the board. Did I put them in from the wrong side?
The threaded 6-32 standoffs that are soldered in the backplanes??? If so, you are not the first to do that...how about a close up of the backplanes??
grapplesaw
Vancouver
Here is a shot. The threaded standoff's were soldered from the bottom and the little inserts for the drivers were soldered from the top as in attached photo
grapplesaw
Vancouver
Here is the DC offset at outputs 3mv and .8 mv
Any fine tuning this ??
I will have to redo this one
I just noticed it was set on Ac volts
Well you got me after all Lee!!!
I retested with the meters set on DC volts and got unexpected results. Less than .1 MV in each channel. Does this look right seams to low.
I have left out of the input the high pass cap and resistor and wired direct from the RCA plug to the volume controls.
#45
DC offset using the Rev E board with the OPA op-amps are typically .000, to .001 VDC.....ZERO to 1 millivolt...
grapplesaw
Vancouver
Help please. On load test I get wave distortion on bottom half and on both channels area identical. THD is very low and this was at about 1 volts output when this started. The more volts the greater the distortion
I Tried two different source supply for input so suspect something in the power supply bridge rectifier area
Any thoughts
Did I cook one of the small caps on the bridge rectifier???? I think that because it is equal distortion both channels and only one channel fuses installed at a time it has to be supply cap side or main control board. Could bias transistors cause any effect?? I will isolate the DCP board and check bridge rec with meter next I guess
Glen
#49
One channel fuses at a time?? You mean rail fuses?? Put all 4 in and try it again....
#52
Glen, IIRC , there's something weird that happens when all rail fuses are not in and functioning....
grapplesaw
Vancouver
I bypassed the DCP board
That eliminated that and any concern of the supply lines running between the DCP board and binding post
I all removed all other test leafs from unit
grapplesaw
Vancouver
Gets worse the lower the frequency......what power output??
50 mv input wide open volume control and wave Starr's to break up on bottom half of wave at1.7 volts output with 7 of ohm load
The voltage point has increased over time before distortion
Here is a pushed up voltage photo at 2500 hz
