I was doing something different with this build so I try several new ideas. I spaced the control board about 1/2" higher to give more room and cooling area
The clips made it easy to hold the wiring about half way between the back plate and control board
Glen, on some early builds of mine I actually relocated the AC mains in and fuse to the left side between the big caps. That was actually a pretty clean installation...
Ok here's the whole story. I saw your posts some years ago about doing just that. I believe the cord came out the side by the transformer. I did not want to have the power cord showing like that so never wanted to try it. After looking and thinking about it I drew up a wider chassis and discussed the potential to build it at Joe's fabricator. Joe said it would be way to expensive so I ditched the idea. Having purchased a chassis from Joe I was eyeing at the left over and thus we have this build. Go or bad it was just fun to do.
The hardest part was putting in the drivers. I remembered something about magnets so I got out my little pocket magnet pencil It made things much easier but still was a fight
I found that checking the leg alinement in an old base helped a lot
I must have stewed up something with the little inserts as they stuck up from the board. Did I put them in from the wrong side?
