- Jan 14, 2011
- Gillette, Wyo.
Coolness Glen!!
It is Alive
The hardest part was putting in the drivers. I remembered something about magnets so I got out my little pocket magnet pencil It made things much easier but still was a fight
I found that checking the leg alinement in an old base helped a lot
I must have stewed up something with the little inserts as they stuck up from the board. Did I put them in from the wrong side?
The threaded 6-32 standoffs that are soldered in the backplanes??? If so, you are not the first to do that...how about a close up of the backplanes??
Here is the DC offset at outputs 3mv and .8 mv
Any fine tuning this ??
I will have to redo this one
I just noticed it was set on Ac volts
Well you got me after all Lee!!!
Here is a shot. The threaded standoff's were soldered from the bottom and the little inserts for the drivers were soldered from the top as in attached photo
At ALL frequencies??
Glen, IIRC , there's something weird that happens when all rail fuses are not in and functioning....
Amen, I see Joe is here, time for him to chime in...
Have you swapped in an amp that has tested clean??
