- Jan 14, 2011
- Gillette, Wyo.
That Glen feller is a heck of a man!#!#!
Definitely a great catch! I've also had those phx connectors disintegrate on other builds and ended up replacing them. Were there physical breaks in the traces that you could see??
It sounded like the connector not the board.
So this one is a mistery to me as well.
The phoenix connectors are all ok. The traces must be lifted off the board under the relays and connectors , although no sign of visible breakage on the traces, two were conductive with ohm meter but wouldn't pass any voltage. Go figure. In the end we jumped from the Phoenix pin the the relay pin soldering point on both and from the replay output to the binding post connection on Right only.
Hope it it works or it will get a new DCP board next look.
this board had two two pin and one three pin connectors. This connecting flexes when you tighten the screws. A one pieces seven pin connector is much more stiff and dose not put stress on the solder joint like the short ones do
Via??
Hooked the amp up tonight and both channels are good. Hoping it doesn't return but historically, there were/could be long periods of working correctly between episodes of channel dropping.
I'll bite. What is VIA??Sounds like a damaged via...
Got itThe node point (pass-throughs spot) of a circuit from one layer of a printed circuit board to another.
That would appear to be the case.
I have not confronted a board of this construction before. My "technique'" for removing the relays involved a handheld, spring loaded solder sucker and solder wick. Unfortunately neither on it's own or a combination of the two was successful in disengaging all pins of the relay. So yes, a further combination of heat and prying was needed to extract some pins from their holes.
As mentioned before, there was a pre-existing intermittent channel condition which it seems I exacerbated by removing the relay.
