- Jan 14, 2011
- Gillette, Wyo.
Bypass the relay to make sure that's it. Run a jumper from the input of the DC board to the speaker post...
I could not deal with those protection board relays until today. I'm too bagged Mon to Fri from being gone from home 17 hours per day and Saturday is usually the day I don't have to work.
The board was off, under a magnifier and I removed the newly installed relays to clean up anything that might cause a bad solder connection. Didn't see much so re-installed the relays. Although the relays both click and the meters are working, there is now no audio at all getting to the speakers on either channel.
Not sure what's with this board but I think I'll just cut to the quick and get another one. Anyone have contact info for Don Imlay or should I just go through the Watts Abundant website?
And FWIW, this is how the board is wired back into place.
I am wondering if you have two AC and one ground going to the board
unlike the 400 which has only one power supply leg to the board the 700 needs both
you pictures look like they have only the one supply and one ground.
Please see photo for connections
Thanks Lee for clearing that up.Jerry modified that board Glen , those connections aren't valid now...
You betcha...
we'll have to remember that. I hadn't seen a relay on the DCP boards go bad yet so I was kinda wondering.
