We've had a disaster in the field. I'm gonna be gone the rest of the day...
I also had trouble sourcing these fuses. I simply replaced the fuse holders with the same type visually, but that accept the longer style fuse. I then used common replacements with the same value. Not long after I had done this, I found a supplier in Canada that stocks the agx. Nutech electronics.Where are you guys buying these fuses and what are you spending? Kind of stinks that parts express doesn't stock AGX fuses, and radioshack / mouser / digikey don't stock deoxit. So I can't simply place one order for anything anywhere! I should be able to use 250v fuses in place of the 125v versions so long as the form factor is appropriately agc or agx with the correct amperage right?
AGX 5 fuses (supply)
AGX 8 fuses (supply)
AGC 10 fuses (line)
.125 AGC fuses (llittelfuse USA 312 3AG 1/8A 250v) (preamp)
The holders I found at an electronics shop were identical to the old ones, only for the longer fuse. They were dirt cheap and direct replacement with no mods. Two solder joints each and dunzo. From the outside they are visually identical and from the inside are only a blonde one longer than the originals. I can get fuses at my local hardware store or auto parts for under a buck each.Haha! Mouser wants to charge me $42 for some damn fuses! These fuses are pretty ridiculous. It sure seems appealing swapping out the fuse holders, do you have a writeup on that?
