- Jan 14, 2011
- Gillette, Wyo.
Sounds good. I have several thousand of those small transistors....
Welp, I still have the problem, so I suppose I should swap a few parts. Would you suggest Q1 and Q2? Anything else? Gepetto mentioned those Q5 pinwheels might be a culprit.If it's still noisy, and you want to try and fix the factory board I have lots of whatever it takes to fix it...
Just checked again with probes in place before powering up and the numbers do pretty much match. 0.2mv left, 17.5mv right.It should trip seconds after you power up, that closes the contacts on the relay, when DC is present at about 1/2 volt and up it will open the contacts as will powering down,....
I do have a solder sucker and some copper wick. Recently purchased a KSGER T12 soldering station. Cheap, but seems to hold temp well and came with a nice narrow tip.That's correct. I'll start putting together the care package tonight. What do you have for a soldering Iron? Desolderer or solder sucker? The traces on that board are not forgiving of overheating. You need to melt the solder and get the component OUT!
Cut the leads on the transistors if you can and remove one at a time. Trying to melt all 3 leads and get it pulled exposes those traces to wayyyyy to much heat. On the caps, melt one pad while pushing the cap sideways to get that lead pulled, then do the other. A little cool down between leads is not a bad idea either.
Search and dowload the datasheets for TIS97's, MPSA93's, 2N3439, and 2N5416. Download the datasheets for whatever is in there for transistors now so you can compare pinouts and install the new parts in the correct orientation.
I will look into it. Thanks!Solder suckers and vacuum cleaners are the only thing designed to suck and they do a poor job of it. Many a board has been trashed with them. Solder wick can cause problems as you tend to put too much pressure on the board. Lifted tracks prevail. The Hakko desoldering tool works great. The knockoffs at 1/2 the price may work.
