- Jan 14, 2011
- Gillette, Wyo.
Good one Gadget!!!!!
It looks like the one you used in Przem's buildNice switch....
Well Lee I guess you started that spring clean early. Thanks for lookingOk Glen, I have literally tore the man cave up, and other than find a bunch of stuff from Nav I had forgotten I had, I have no pushbutton. I have the meter-range switch and endbell.....I have a bunch of pushbuttons for the 3300 Ser II. But I think the one's you need are a lot skinnier....
Glen.. Jani is cutting my hair at the moment but when she's done I'll measure those knobs and take a pic.
That is it3/16 X 1/2 X 1/2......
That sounds realy goodYou bought an unpopulated board?? If you can wait two weeks I'll send all the components to populate your board too. No sense in buying singles of everything you need. I don't think the price break is that great on anything except the relays...
