Don Imlay's Phase Linear 400 Series II Quasi -Comp.
DAYAM!!!! Like a black hole for noise. With pre-amp at null, no noise, with pre-amp at 0db( which i have done only twice before) barely audible. This IS the quietest amp I have heard here.
Crosstalk
A to B , output 18volts, input 500mv, 1KHZ------ Minus 80.92 db
B to A, output 18.020 volts, input 500mv-----Minus 90.86db
Signal to noise ratio-unweighted 10 to 80khz
A ---@100.1 mv input and 1.014 khz------82.9 db
B----@ 100.1 mv input and 1.014 khz-----82.5db
Signal to noise ratio-unweighted 10- 80khz
A----@ 500 mv input and 1.001 khz-----95.3db
B-----@ 500 mv input and 1.001 khz-----95.6 db
Its one of the few upsides to getting older and losing our hearing, our amps just sound quieter :) Nice work Lee.
That's why as you get older your instruments must get better. Thanks Joe, appreciate that.
I humbly admit I have forgotten a most important test----------------frequency response-----a test the AP is ideally suited. I shall remedy this omission forthwith.
Lee's Testing Service. Send your amps and pre-amps, Lee will test the heck out of them. No amp too big or too small, come one come all, to Lee's Testing Service.
Joe----when running a freq response sweep, and you can zero your reference level, what level is recognized as standard, or is there one??
It varies but a lot of time you see 1W output cited as the power level that the frequency response is measured at. For this amp a more meaningful level would be 10W into 8 ohms IMO.
Might have went over that. I did one with 0dbr at 250mv input correlating to 9.021 volt output all into 8 ohms. I did a second one at 500mv input and 18.023 output. Almost idedntical results.
I will run one at 10 watts.
