- Jan 14, 2011
- Gillette, Wyo.
Is there a resistor on the light board we can replace to drop the input voltage?
Joe, have you ever measured the display voltage on a Ser II?
Do you have a series 2 transformer in that 700B you are making for Derek?
Jer, the LED displays have some IC's in em. I'm thinkin they might be 15volt? or 8 per side?
IC's look to be a UAA170....
Great minds... LOL.
Yeah, about 12 volts dc. Hey.. heck man.. feed it with a variac, and while you are watching both the DC output (should be the red wire that goes between the two channel displays not the right channel from the amp) and the led's dial it in for 12 volts DC for B+
D2, everything has been upgraded. We now use 50 amp bridge rectifiers, the outputs are the finest made nowadays, wayyyyyyy better than the originals. They are quieter, cleaner and much more reliable..
There is so much that has been changed it would take a day to tell you...
