BIG problems
Michael F
Montreal Canada
Damn I wish my care package had gone thru. It had all the caps you needed for both channels, C3, C11, C6, C15, C16. All Nichicon KZ (Muse) series. In the factory boards, you can drill out the component thru holes. I use a cutting torch cleaning set which is a pin vise with very small drill bits. Those caps I'm not familiar with. Should get you up and running though. Got a cap checker on your meter??
That would have taken care of all the electrolytics, with nice caps too. Were those values altered as well? But if one were to change only one cap it would be C6.
I`ll put the new ones in along with the diodes. While not Muse, they must be better than whats in there now I suppose.
fitz43
Lower Mainland, BC, Canada
Where did it end up?
Michael F
Montreal Canada
Been busy.
Star ground scheme
DONE
C6/diode mod
DONE
Q`s 1,2,3,4,5,6,7,8,9,10 replacement
DONE
I`ll start mounting the drivers and outputs tomorrow.
I bought me a nice Xcelite 12" long nutdriver with a magnetic 1/4 socket to remove the 48 TO-3 screws, made things sooo much easier. Would using a telescopic magnet be a good idea to re-insert the semi`s or can the magnetic field potentially damage the junctions?
What method do you guys use?
I use a mag head 1/4" bit driver. Find em by the dozen at the local hardware store. Gewt the thin walled one. Might have to grind some off the sidewall of the bit anyway.
Drivers FIRST,, bring it up THEN THE next row of outputs------One row at a time Lad.
Michael F
Montreal Canada
Hmmm... Change of plan then. I wanted to mount the TO-3s in order to replace the emitter resistors, much easier to do when sockets are in the right position.
I don't understand what you mean by "THEN THE next row of outputs"
Star ground scheme
DONE
C6/diode mod
DONE
DONE
Hi Mike
I don't think you have the star point ground quite right yet. I think I still see the 220K resistors running from the normal-direct switch to chassis ground. If my reading of your photo is correct then this has to be fixed. I sent you a photo earlier of the recommended wiring scheme.
From the bottom of the chassis up there is one row of drivers and 5 rows of outputs going horizontally accross the back. Vertical rows, one at a time.
Don't need the outputs in to hold the sockets in. Run the holddown screws in alone to hold em.
Michael F
Montreal Canada
Hi Mike
Nice catch Joe!
100 watt is fine, the bulb will start out very bright AND IMMEDIATELY start to dim. That's what you are looking for, if it starts to dim, adjust bias as soon as you can. Have your meter hooked up to the bias points and ready to go.
Michael F
Montreal Canada
All right then. I`m pretty sure the driver and output transistors Lee is sending over are worthy of your confidence :)
So if I understand the initial power up process correctly, with B+/- fuses replaced with 200R resistors and a 40w bulb, working one channel at a time:
Turn amp on with driver board alone. If good, proceed to installing drivers. If good, move on to measuring DC offset and adjusting bias according to service manual. If good, install output transistors, cross fingers, say a prayer to the Audio Gods and turn amp on.
Does that sound about right?
I`ll do the initial test with the drivers in position as per Lee`s suggestion . I managed to borrow a variac from a place I work at for the weekend.
Is the combination of variac, DBT and 200R "rail fuses over-cautious?
