- Jan 14, 2011
- Gillette, Wyo.
Those are outputs.
Who is the seller?
A gentlemen from Blackwood NJ, EBay handle Qua-co.
OK, that is not great advice for the quasi comp. It may work sometimes but is not the proper recommendation as it can lead to oscillation on the lower half signal.
What do you have in the amp for the pre-drivers now? The pre-driver is the bottom TO-3 position on each vertical column. They are usually RCA410 (the best) or SJ2741 or
66546 or the like.
Did you already purchase the transistors or are you just emailing back and forth at this point?
Are you referring to the input switch as the "Direct/Normal" switch on the back??
I`ll begin this next phase (pardon the pun) with a new grounding scheme. My interpretation of Gepetto`s diagram is as follows:
*Buss bar to center terminal of Left channel backside terminal strip
*Left channel center terminal to center terminal of Right channel backside terminal strip
factory wire from input switch to right channel terminal to be removed
Correct, to be removed
*Buss bar to PL14a Chassis Ground pad
that pad used to get its ground from input/output terminal grounds?
Correct, it used to but it should connector to bus bar star point ground.
*Buss bar to light board (pad 4?) on WO light board
*Buss bar to Left and Right negative output terminals
input jacks and switch chassis grounded through input/volume pot wire shields to PL14
Correct except that there is NO ground applied to the switch, that is unnecessary.
The schematic is quite literal, you have correctly interpreted it with all your comments except for the one about the switch ground.
See picture below for a method on how the switch and inputs are handled.
Does this sound about right?
The series II quasi and complementary also used the same transistor in output and driver stage when original devices became obsolete. As for the caps, I would have to look at your order. What value do you have to many of. Let me know, Ed"
Make sense?
I question the validity of that statement.
Be sure C6 is audio grade...
On that factory board, I have bent cap leads 180 , then brought them in a little then bent them back down. Post a pic of the cap.
