700 Series II Build
Hexis22
Wisconsin
#61
Fully assembled, meters calibrated, output power confirmed with symmetrical clipping, and initial listening tests completed.
Time to move into main listening room for the real sound performance evaluation.
I now have a completed pair of 100% hand assembled, upgraded, and restored matching Black beauties...
bscote
#62
Finally getting around to building myself a 700 after finding a Series II with functioning donor components, not the best cosmetically but will do given the price.
After finishing a 700B for a customer, I'm looking forward to having a 700 to use when I want a concert in my living room. I also liked the front panel On/Off and meter sensitivity switch features.
I will most likely update my 400 S2 with a meter sensitivity switch as well. I call it the Wife sensitivity switch, the meters don't usually move much when she's home...
I plan a full White Oak upgrade including new chassis and faceplate.
Here is what I have to work with, it's all stock except a large variation of replacement outputs with SIL pads AND thermal grease:
The good thing is that that amp is the full complementary version. Did you use the original output transistors?
Hexis22
Wisconsin
#66
That is some truly beautiful work you did with the installations and wiring!
Thank you.
White Oak offers new ON Semi output drivers (MJ21195G, MJ21196G) at competitive pricing.
https://www.whiteoakaudio.com/estore.aspx
The White Oak backplane boards are only full complementary output by design.
Highly recommend replacing 40 year old output drivers due to unknown history, thermal cycling, and significant improvements with modern materials and manufacturing techniques with new devices.
Minnesota
#68
Looks Cool
Did you buy new Volume Knob? if yes do you have a part Number?
thanks
Steve
Finland via the deep south
Details, details
#76
Chassis assembly has started.
Going with a barrier terminal block for terminating the transformer.
Edit: In true Phase Linear fashion, this transformer was wired with the solid conductors closest to the core. All others I've worked with had the striped wires at the core. I guess I should not be surprised, considering it was most likely not specified combined with the use of non-polarized plugs at that time.
Drilled out and chamfered all heat sink TO-3 mounting holes for correct aliment with chassis.
Started AC wire routing and incorporated one of Don's Triac power switches.
Lots of fun new updates on this build...
Pretty slick how you used the spade fittings on the xfmr leads at the bridge...wouldn't have thought to do that instead of soldering...maybe next time :D:D:D
#77
The snubber board was designed with that in mind. The snubber was designed for the Model ONE that uses Faston connectors on all the wires attached to the bridge.
Dnspy007
Tennessee (Gods Country)
#79
Finished switch updates today.
Replaced both power and meter sensitivity switches and mounted to mid-plate bracket after marking and drilling 2 new holes.
:cool: :cool: I sure would like get a few of those, would you happen to have a part#
