- Jan 14, 2011
- Gillette, Wyo.
Bullshit...
Super CleanAlso completed Cylon meter boards and mounted everything to the mid-plate.
Yes, I jumped on those switches after seeing Sniffs’ post.Excellent! Sniffs' superb heavy duty switch upgrade. Love the feel of those switches. Really nice.
It plays music, hopefully.Makes you wonder what's next...
Running the grounds along the top would make the bundle smaller, but I prefer bundling wires with opposite current (DC Rail feed and Ground return) to help minimize radiation and coupling.Your wiring dressage is very nice. I run the White Ground wires along the Top of the Chassis because the runs are shorter, the Ground wires are inert to the circuitry, and the bundle at the bottom is smaller.
You have nailed it. I have verified with my Audio Precision that bundling them lowers noise and everything else. keep then together and as far from the op amps as possible. Raising the control board 1/2” helps as wellRunning the grounds along the top would make the bundle smaller, but I prefer bundling wires with opposite current (DC Rail feed and Ground return) to help minimize radiation and coupling.
Running DC Rails along the bottom and Ground return along the top potentially creates a large loop antenna within the chassis.
Edit: This is the kind of thing I wish I had a QuantAsylum QA403 audio analyzer to measure and quantify different wiring layouts. Not that I doubt Joe already has this system optimized, I just enjoy learning pros\cons of different ideas.
Eric already has that extra lift Glen. He is using the WO chassis that comes with the longer standoffs.You have nailed it. I have verified with my Audio Precision that bundling them lowers noise and everything else. keep then together and as far from the op amps as possible. Raising the control board 1/2” helps as well
