400/1 “Linda” Full WOPL
AngrySailor
---not quite right
For sure. Tim could use one or two changed out also. Unfortunately there are several broken insulators on Linda, where they pass through the back plane. I won’t toss anything though Lee.
AngrySailor
---not quite right
If they're busted they're too brittle..
Did they bust because brittle or because someone was a caveman putting them output retainer screws in? I notice you have to be careful as the screw goes through the insulator that it’s threads enter the collector tab easily or you would probably bust the insulator?
Mine looked like they pushed the socket away from the wall trying to get the screw started, then once started, snugged it up with a misaligned socket. Probably couldn't see through all that compound they slopped on.
AngrySailor
---not quite right
Mine looked like they pushed the socket away from the wall trying to the screw started, then once started, snugged it up with a misaligned socket. Probably couldn't see through all that compound they slopped on.
That friggin compound... I’ll have nightmares about that slop...
AngrySailor
---not quite right
Btw Mark, never knew you had a YouTube channel, I got videos to watch tonight, looks real cool what I’ve seen.
