AngrySailor
- Oct 15, 2014
- ---not quite right
I’ll keep anything worth keeping. I’ve got a lot of the busted insulator parts also. A little crazy glue could make some useable sockets...If they're junk, dont need em Andrew..
Did they bust because brittle or because someone was a caveman putting them output retainer screws in? I notice you have to be careful as the screw goes through the insulator that it’s threads enter the collector tab easily or you would probably bust the insulator?If they're busted they're too brittle..
Still have mine from the 700, 24, no cracks.Keep the old sockets, I want those.
That friggin compound... I’ll have nightmares about that slop...Mine looked like they pushed the socket away from the wall trying to the screw started, then once started, snugged it up with a misaligned socket. Probably couldn't see through all that compound they slopped on.
Cool, thanks Mark..Still have mine from the 700, 24, no cracks.
Will mail..
You do????Keep the old sockets, I want those.
You do????
Damn. I threw the ones from MY build away? Had I known............Keep the old sockets, I want those.
