- Jan 14, 2011
- Gillette, Wyo.
Me and Nando's folks got close...
Tom Collins comes to my house a lot.Had a visit with Weiser's buddy, ole Pilsner last night as well. Good visit.
Just make sure they are flat and square to the board otherwise the screws that hold the output transistors in, will be cockeyed.Have I got enough solder on these standoffs? You can just see it sweating through the other side most ways around the socket.
I used to get one or two PEMs on each board that were slightly tipped and had to reheat them. I am better at it now, with the help of some springs that hold them down under pressure against the socket head screws.I’ll bring a straight edge in from the shop. They seemed to all sit down nice, I was able to give them a spin with the iron tip also.
one done.
I pre-bend the leads and solder them on the bench to have the P-straps match the silkscreen outline on the board. You just have to make sure they don't protrude too far down below the board. But if you get the bends just right, there is nothing to trim off.And on installing those bias transistors,
