- Jan 14, 2011
- Gillette, Wyo.
Nice approach Jer..
Thanks Lee.. yeah here they are in the middle of the heatsinks. Good airflow... should keep it cool for Ron!
Ah. A new nickname The Navanism....
! No more giant box fan on top!!!! Did you use velcro to mount the fans? How are they held in place?Looks great Jer! No more giant box fan on top!!!! Did you use velcro to mount the fans? How are they held in place?
So, will this fan mod be known as the Northwinds Mod now for super duty applications LMAO. It would be fitting since it is as cooling as a North Wind
Jer, are the covers off the back so the airflow is direct on the power caps? I was wondering if I could cut the cover plate centers out and fab screens on them to allow air to get in but keep fingers out? I imagine the covers keep quite a bit of localized heat in
Another kickass WOPL is born!!!!! Thank you!!!!
Sounds good Jer (at least what a camera can record). I tend to run the meters a lot higher... 0dbs and higher, lets see them up some and the fans doing their job. That's the real test... the Ron test, where the amp gets as hot as the surface of the Sun LMAO
Nice! I am stoked! I guess I will plan on getting Blackie ready to send to you then when this one gets here. AWESOME job Jer!!!
