- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
The stock jacks are 3/8' (.375). The Mouser jacks are slightly larger (.394) and will likely require drilling the fiber washer and bus bar. Of greater concern is the fact that mouser jacks mount on the front of the chassis, with the nut on the inside of the amp. The stock jacks are Switchcraft 3501FR which mount from the inside of the chassis with the nut of the outside.
I don't think it would be worth the effort to try the Mouser jacks.
