Speakerman knows the signals should be split, or in this case high-pass filtered, before they go to the drivers. It should not matter if there is 1 tweeter or 100 tweeters as long as they are wired in a series parallel convention to equal 16 Ohms. I assume you are talking about supplying a crossover for each speaker? That would be a huge waste of components, not to mention the huge insertion loss to the audio signal.
If your tweeters or mids will not go down to 500 Hz in frequency response then the JBL 3160 is not for you. I would be looking at a JBL 3120A with a crossover at 1250 Hz or even a JBL 3105 with a crossover at 7000 Hz.
The JBL is the only crossover that I am familiar with that will handle 600 Watts RMS all day long.
I'm just sayin' if you are connecting a crossover to a WOPL 1000 (formerly Phase Linear 700/700B) then you need a JBL 3160 in your speaker design.
Mark
Mark
