- Jan 14, 2011
- Gillette, Wyo.
Why 250 volt Jer? Those 15K-150's would fit wouldn't they?
Hey Jer, what's the voltage at the rails by chance (if you had a chance to check). The WOPL700 hits 1000w at around 107 right? Just wondered what this one was at or if that measurement would even apply to this type amp. Would love to know exactly what this baby pushes
Not exactly... From what I can decipher, the mag field amps actually have 3 "rails"... sort of... +/- 50, 80, and topping it out at 122 thereabouts. Can't really compare.
Hmm... so one thing.. you said ya heard a "subdued buzz"?? I can hear it .. but that's only if I am a good 6 inches or closer to the tweeters. We'll have to see if the main caps help that any, but if not hmmm... well, we'll "see". Just noticed in my email the caps are being shipped so it should be 2 days til we get those in.
Apologies good sirs; I have no business to butt inhere; but in my ventures in trying to dig up research on my fathers gear; I thought maybe the Carver site could be of some use to you? I did not see it on the forum here in suggested links. There seems to be rebuilds for each individual amp, even this one. Perhaps this could assist you in some kind of way? If not be a fun read? I shall depart now with narry another word on this topic......
http://thecarversite.com/yetanotherforum/default.aspx?g=topics&f=100
There is no such thing as bad advice, thank you! The Carver site though is filled with speculation and constant warnings that more of these amps are destroyed while fixing them by people who are not familiar with them but no direct answers. I have great confidence that Jer and our other experience fixers will get this baby up, done right and reliable. Some of the most knowledgeable people that I know of are on this board and my faith is in them, not a bunch of doomsayers
The desigh of the power supply, involves triacs, triacs are noisy.
Jer, try flipping the polarity of the plug. Yep, that sub-dued hum is why I sent it to you. Everywhere I read said the 50/80 deal would correct it but who knows. I really think a 3 prong plug is needed these days. That hum has to be some sort of ground issue BUT I have also read that the mag coil needs to be tightened down in some cases but that's something you might want to read up on at the Carver site. Something about a vibration that is transferred to the cover???
"Are you certain that the noise is coming from the speakers?
Disconnect the preamp inputs and speaker cables and power it up.
If you still hear the buzz it's probably caused by magnetostriction in the mag field coil.
Voids in the windings allow the wires to rub against each other as the magnetic fields reverse.
All transformers do this to some extent and mag field coils seem to be more prone.
Unfortunately there is no "cure", however, there are a few things that may reduce the magnitude:
- tighten the bolts that hold the mag field coil to the bottom panel
- install fiber washers on both sides of each of the mag field coil feet to isolate it from the chassis
- add a piece of insulation to the cover directly above the coil (both my M-1.5t's came that way from the factory)
- line the cover with Dynamat or a similar sound-deadening material (DO NOT BLOCK THE VENT HOLES!)
You mentioned the buzz is coming from your tweeters? The infamous 60Hz hum would be most evident in the woofers, being designed to reproduce that frequency band specifically. If the sound is in both woofer and tweeter speakers, I would be temped to use the amp as a boat anchor. If the hum is only present in the tweeters, you have a classic 60 Hz harmonic issue that the circuitry in the amplifier is designed to reject, or your speaker crossover networks are mis-wired. It does not sound like an oscillation or "motorboating" sound?
I am not familiar with the Carver signal conditioning in the front end of the amp nor the filtering in the output section, but if this hum is coming through both L and R channels (I didn't see that in the post) it is likely originating in the power supply section. Obviously, if it is stronger on one side, that would be the side to troubleshoot.
I would start by placing .047/100V poly caps across all large capacitors to see if that makes any difference (easy), then I would place .005uF/250VAC X-type capacitors on both legs of the incoming power line grounded right at the case entry location (harder). Finally, I would install a power line conditioner inside the case and use a three-wire power cord to connect to the power line conditioner and ground the center conductor of the cord to a shiny place on the chassis with a star-shaped lockwasher on both sides of the lug (more harder).
I would love to put the output of that amp on a 250Mhz oscilloscope or audio analyzer with a 2KHz test signal or sweep the spectrum and find the exact profile of the "buzz" you are struggling with. Another thought - if you short the inputs, does it change the hum? That would point to a signal conditioning issue. Maybe front-end signal caps in both channels failed at the same time. Stranger things have happened.
Mark
Your equipment is in good hands with Jer. It will be good for all of us to learn what is causing the hum and how it can be fixed or at least reduced.
Mark
Haven't studied it in huge detail but would hunch that it is that triac regulator circuit on the AC primary attempting to regulate secondary voltages that you hear buzzing. That will throw off all kinds of harmonics that will make its way into your tweeters.
Joe, what do you think about the magnetostriction angle that the Carver guys spout off about? From what I have read, if it was magnetostriction, then the amp would buzz when no speakers are plugged in and I already checked that before I sent it to Jer. What your suggesting as a culprit seems plausible even with my extremely limited knowledge. This coincides with Lee's assertion that triacs are noisy so could that triac circuit be going bad? I am pretty sure when new that amp did not have that faint hum, the Stereo mags of the 80s would have tore Bob a new ass if it did
