- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
Thanks for the info, Ron. We'll know more when the new caps come in today and I'm able to get back to it.
Ron, that post from the AK'er sounds like he knows his shit....
Jer, did you get those D9's thumping lastnight with the old biggun's?
Joe I sent ya the manual. Bias adj you would think be straight forward, but I can't believe the current read is 0v... are they saying have the signal applied above it, and that is what I need to do first?![]()
OH????? Jer, do you have a distortion instrument?? May have to reroute that bugger to AP-ville on the way to Ron.
What bias adjust Jer? This amp does not have one. Also does not have a THD rating. Not surprised.
You can't fix what was designed in Lee
Joe, if there is no THD rating, what is the rating they give mean??? (IM Distortion 0.15% SMPTE)
I'm starting to get a queasy feeling in my stomach, like I made a huge mistake and traded my rarest Beatles lps away for a pile of junk
Jer you set the idle current on this amp. Adjust RP1 so that you achieve 4mV measured across R87 which is near the output stages of the amp, should be a large 5W cement resistor.
That's what I did, it measured around 0 even before adjustment. But further above that step it states to drive the amp to 1 vRMS. Not sure if that should be applied while adjusting the bias.
