- Jan 14, 2011
- Gillette, Wyo.
The Pig is now retrofitted with Joe's latest and greatest. The "D" board as BOM'd for a quasi 400, the R38,39 resistors have been changed to 15 ohms, the bias now set at 510mv. Needed a new set of input jacks, and some shielded wires from the input jacks to the board then on the AP it goes.
It will get a complete test suite with no filters from 10 hz to 80Khz, which is our standard , but not the worlds. It will then get another round of testing with the IEC "A" weighted filter so you can compare to published specs of other amps. Another 30 minutes and I'll have it on the AP.
The Zoebel network will be 2-10 ohm, 5 watt MO 1%, with a .1uf 250 volt polypro cap.
