Kenny Nelson's WOPL 400 conversion.
#61
very pretty work Lee...I think you should leave the front panel off to show off your work.
#64
Thanks joe. I like the way this one turned out too. Can't believe how quiet it is. With no source turned on, pre-amp at full (>5 volts) ear up to the mid horn not perceptible!! I did reroute the AC in this one. I'm real interested to see the S/N ratio.
Mark, this would have been in the period where Bob's brother was winding them, so.......
#65
Getting that AC segregated makes a definite difference. Working on that in a 700B right now.
#66
Lee, you have a 'scope, you might have to use a cord cheater to unground it. You can center the Time/Div to show 60Hz (10 msec/div works good for me) and run the probe around inside the chassis of the amplifier to locate the hotspots (hum). I was surprised where I found the most hum, and it was easy to fix by moving the wire. If there is a loose AC connection, your 'scope will read off the scale.
Mark
Eufaula, Ok
---I like to Rock
#69
DAYAM! This thing os DEAD QUIET!! S/N ratio outta be a killer. Don't know if it's the fact that I haven't had a 700 in awhile and I'm pushing this that hard, but I"M KNOCKIN SHIT OFF THE WALLS!!!! WITH A 400!!!! Maybe I've never pushed a 400 White Oaked this hard, but man, this is tits!!
I like knockin shit off the walls. Lol. What an amazing job you have been doing on my little amp. Little but with a big stick that is. Lol. Bet you've pushed one that hard too. Just ya get better ever time ya do one. I dont know but like I said even sick it kicked ass. Maybe just got the Lucky Shit.
#70
Shakin er down while Jani does her magic on the faceplate.... The Crystal method---Vegas---
Kenny I'm burning some Shpongle and Younger B rother to send with it....
Eufaula, Ok
---I like to Rock
#71
Awesome. Btw we still need to work the deal on the 3300 and 1000 too. Got my 5000 in Friday. Have to fix the power switch though. Its loose. I want to clean all the controls anyway. Cant wait till LS gets here. I have been giving the pig quite the work out too. Also hooked up my Norman Labs Model 82's as front speakers on my surround system replacing the front Mirage nanoset's. Made a big difference. Any music ya can think of I might burn for ya. Do you have a turntable or rtr.
speakerman1
OZONE ALLEY MARS (Visitor)
Wasted Days and Wasted Nights
#75
Yes he has a TT. Chicken won't play it. LOL
#76
CHICKEN????? Those meds must be good!!
Lickety Split drove the horns to a very respectable 119 DB. There was more to get, but I don't want to blow it up before I run the final tests.
speakerman1
#77
I have a pair of NL 7s.
speakerman1
#79
Yes sir. I really like the 7's and 8's. The 82's are pretty small. Extremely well made and really worked well replacing the front satellite speakers on the Denon surround sound system.
I am in the process of rebuilding them. With all new drivers. Pull one tweeter and put a mid it its place.
#80
Kenny, when "Cathy" is done testing Lickety Split willcome out of rotation for it's final testing and cosmetic assembly. Then in the cabbage case. Hate to let this one go, DEAD QUIET and clear as hells bells.... jani has bead blasted and repainted the bezels and p[olished the face plate....
