THEY"RE HERE!!!!!!!!!!!!!!!!!!!!! SONIPHASE S6
Skratch
Huntley Il.
#21
Lee, You could put them on the back of the Sterling and hook them up and ride through Gillette playing Star Sphongled Banner and see how long it takes the boys in blue to pull you over. I did that a long time ago with my Altec's playing Christmas music. That is when I was a lot smarter than I am today
#24
I always thought that if you had K-horns, you never needed any other speaker again...
That statement was probably made by a sane man. My K's are KINOS (K-Horns in name only) They now have a Crites 1526S woofer, a Martelli Tractix wood 2" horn, a B & C DCM 2" horn driver, and a B & C DC10 tweeter. Absolutely killer combination. AS clear and loud as you would ever want. BUT---when someone who has heard my setup says you ought to try these, I'm game. Got the EVX-155 drivers yesterday. Didn't get in till early this morning from work, so it'll be tonight before I get em in.
kevin
Forum Veteran and Hillbilly
Wise VA
#25
I sure wish you would hurry !!!!
kevin
Wise VA
#26
I know this is the wrong place for this question but im going to ask anyway...Why.... When I try to look at pics on here or when I reply like I did above do I get kicked out and have to sign back in before I can post.... Anybody else have that trouble ???
#27
Easy, use the "close" on the bottom right of the pic box, then you should be back where you were when you hit the pic button.
#28
Also, clic the "remember me" box when you log in. If you don't it'll kick you to the curb after a certain amount of no activity, no I don't know exactly what that amount is, less than 15 min though.
#29
THESE THINGS ARE MASSIVE!!!!!!!!!!!!!!!!!!! 25 pounds of kick-ass woofer!!!!!!!!!!!! That's a very big hand trying to cover that magnet structure!! 4" voice coil, oh man..............................
#31
Or at least provide the signal for seismographers. They use "thumper" trucks a lot instead of dynamite. Perhaps we shopuld present them with theoption of ......say..... EVX-155 shock waves..........????????????
Kevin--heard Alpha is laying off another 1200, most of them in your area, jeez man how much more can you guys take...
#32
Mark, all 8 holes on the motorboard to hold the massive beast all line up perfectly!!! You did all the hard work, shit, all I have to do is throw the driver in and go!!! Once again BEAUTIFUL JOB on the cabinets man!!
#33
Was warming up the ears on some Whirly Gig-- about Mach 7 ---didn't have the fan on in the Larrt's 700 and kicked the thermodiscs out----Temp????--192 degrees F.
Skratch
Huntley Il.
#35
Its amazing what a person could do with the help of technology
Skratch
Huntley Il.
#37
Yes sir, Where are you coming in with the speaker wire. I came in just above the woofer on the bottom side of the reflex port
#38
Me too, had oriented the woof with the terminals facing up. I have some copper 10-32 machine screws 1-1/2 long i'll use to go through then just attach the wires to them.
