The format you want is DXF and I have the program to take a PNG or Jpeg, Bit Map, or SVG style image file, load it into the program to convert it to DXF format, through a few steps, the CAD programs use the DXF. Then when you load the DXF you converted to. Make the drawing/s RCA's chematic and then click on "Generate Gerber" and take the Gerber to your fav chinee PCB facility, and you'll have the the chance to order the boards in any color, and any Qty you want along with the thickness. The fiberglass boards Should be beefy enough to handle 2 RCA Jacks as long as you don't use the toothed washer and twist the hell out of it.
