- Jan 14, 2011
- Gillette, Wyo.
Crank it to 11 and hold on…
My kinda guy right there!!
I’ll pull together the relevant White Oak documents for setup and operation and include with the amp.
Not yet.Have you run it hard enough to need forced air cooling?
With the amount of headroom designed into this amp, my initial listening tests produced amp temperatures only slightly above ambient. Although Lee will provide the true litmus test on output power and resulting amp temperature…
This is truly a very special amp Joe has designed.
I do think Lee is the best recourse for this portion of the testing............Lee do you have spare drivers ready??
Lee has a particular set of skills, skills he has developed over a long period of time, skills that are a nightmare for drivers like in speakers......................
Absolutely!! Somebody has to do it.. .I should be able to warm those heatsinks up.
Have 4 spare woofs, 2 spare 4592's, 4- 4592 diaphrams, and 4 spare DE 10's...and looking for diaphrams for the DE 10's. Not a lot aroubd right now for some reason..
B&C bought Eminence correct?
Duty cycle significantly better on thisun sounds likeWhat gage steel will she weld?
