Model ONE Build - S/N 0005 & 0006
Hexis22
Wisconsin
#85
With the amount of headroom designed into this amp, my initial listening tests produced amp temperatures only slightly above ambient. Although Lee will provide the true litmus test on output power and resulting amp temperature…
This is truly a very special amp Joe has designed.
Gibsonian
#86
I do think Lee is the best recourse for this portion of the testing............Lee do you have spare drivers ready??
#89
Absolutely!! Somebody has to do it.. .I should be able to warm those heatsinks up.
Have 4 spare woofs, 2 spare 4592's, 4- 4592 diaphrams, and 4 spare DE 10's...and looking for diaphrams for the DE 10's. Not a lot aroubd right now for some reason..
B&C bought Eminence correct?
#90
Lee has a particular set of skills, skills he has developed over a long period of time, skills that are a nightmare for drivers like in speakers......................
Yep.. and then there's Randy, he was clipping a 700 SerII WOPLon his K's the other day...
Gibsonian
#91
Yes, thanks to you I just learned that. Looks like you are ready to field test the Model One
Hexis22
Wisconsin
#98
Place the separate audio control boards and attach to backplane PCB's.
This design has very direct and compact connections for the critical amp control boards to the backplanes, unlike loops of wire in the traditional Phase Linear configuration.
Place the power control PCB, rectifier, and soft start resistor on the transformer shield.
Hexis22
Wisconsin
#99
Placed thermal switches on the back chassis wall.
Given the large tabs on this switch, it's easier to place after the mounting the backplane boards.
I also placed a VERY small amount of thermal paste on the thermal switches and bias transistor mount for improved thermal transfer from back chassis wall.
