I believe that caps are affecting a sound, but... Take for example some TOTL amp that is built only by the highest quality components. In a such a situations its clear that only the best can be involved. At the same time, when talking about standard music equipment where a manufacturers have used 5% tolerance components it's obvious that 1% would not make any difference.
Back to capacitors itself. When talking about cassette decks and brands like Sony, Technics, Aiwa and others, do you think that caps can make any difference? I mean, Pana FM, FR and Nichi UPW on the one side and UFW, UFG and UKZ on the other side - would it make any difference?
I'm about to recap one of my RS-B965 which is more than 90% filled with some Pana Pureism capacitors (guess it is some audio series caps) which I dont believe are anything better than FM, FR or UPW. Would it give any improvement if I recap a whole deck with audio caps from Nichicon, like UFW or UFG, since it is excellent (when modified) cassette deck but it is still not some 100.000$ gear. Fore example, UKZ is overkill for this purpose and is definitely out of question.
The one can take a Ferrari engine and somehow squeeze it in some standard car which will make that car run faster, but it will anyway not be able to run as fast as a Ferrari. You understand what I mean.
Second and for me eternal question: When they say audio capacitors, does it means that they are made to be generally used in audio equipment or just in a signal path?
